It Shows 0xc004f038 Error While Activating The Keys
Give your views on the 0xc004f038 error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
Windows activation error 0xc004f038 is an error that occurs when the user tries to activate the Key Management Service (KMS) by using the Volume Activation Management Tool (VAMT). It is due to the KMS pool that has less than five client computers. The error message may be seen as “0xc004f038: The Software Licensing Service reported that the computer could not be activated. The count reported by your Key Management Service (KMS) is insufficient. Please contact your system administrator.” The solution to fix the error is:
Solution 1:
Add more clients’ PC to the KMS pool.
Step 1: Open the command prompt as an administrator.
Step 2: Type in slmgr.vbs -dli and then press Enter.
Solution 2:
Update Windows.
Solution 3:
Activate Windows Via Internet
Step 1: Click on the Start option and type slui 3.
Step 2: Input the activation product key.
Step 3: Click on the Activate option.
Notifications
