It Shows An 800ccc0d Error While Using The Outlook Service
Give your views on the 800ccc0d error? Describe the cause of the error and explain various steps to fix the error, and also attach a snapshot of the error.
The 800ccc0d error appears when the user tries to send or receive email messages in Microsoft Outlook. When there is a blockage between the internet and the computer system and the user uses the Outlook service at the same time, then the error code appears. The error message display: “No connection could be made because the target machine actively refused it” or “The server could not be found. (Account:account name, POPserver:’mail’, Error Number: 800ccc0d).”
The steps to fix the error code are as follows:
Step 1: Verify the Connection of the internet.
Step 2: Check the Account Login Details.
• Click on Start > Run.
• Type ‘Control Panel’ then press Enter.
• Open the Mail in the Control Panel.
• Click on “Show profiles” in the Mail setup dialog box.
• On the General tab, under ‘When starting Microsoft Office Outlook,’ click prompt for a profile to be used, and then click Add.
• Type a name in the “Profile Name,” then click on OK.
• Click on Add a new e-mail account, and then click on Next in the E-Mail Account option.
• Click on appropriate server, then click on Next.
• Fill in the account information and then click on Next.
• Click Finish and click on OK.
