It takes a long time for Galaxy S5 to load music files
Hello!
Can you help me with my problem? Can you provide me instructions on how to resolve this? I am having difficult times in playing and or loading my music files. Most of the time it will take a very long time load the files. Is there any reason why this is happening with my phone? Do I need to back up now my files? Could it be a virus infections? Can you provide resolution on how to resolve this problem? Can you provide me also alternative way on how to resolve this?
Thank you!
Answered By 5 points N/A #190120
If your phone is experiencing file loading trouble loading file, it means that either your device memory has become old and outworn or your software is experiencing trouble accessing the disk.
First of all, restart your phone. Hold on the “Power” button and select “Restart”.
Next, try cleaning the cache of your device. They take quite a large space and might cause slowing down the data reading process. You can use any good app like Clean Master, CCleaner etc.
Uninstall your player and re-install it again. You can use any good media player like MX Player, VLC for Android etc.
If still no solution, then backup your music files and delete them and get them back from the backup again.
Make sure that you have the latest update for your Android.
1. Connect to internet on your phone.
2. Go to Apps >> Settings >> About device >> Software update >> Update.
3. Wait until download ends.
4. Install the update.
Hope that your phone is in smooth and speedy form now.
