Is it true if I upgrade the RAM, VGA also added?
Hi All,
My friend said he had a friend, his friend had a laptop with built
2 Giga RAM. he did expandable to 6GB …
Continue to congenital 1 GB VGA…
He said after his expandable RAM and VGA so its 6Gb also be up to 3 Giga…
What's really?
What's it matter?
thanks
Best Answer by newaji@hotmail.com
Answered By 0 points N/A #99063
Increasing your ram will allow your computer to multitask and have a smoother experience. Your laptop uses a shared architecture and increasing your ram will help your video performance.If Your graphics card has built-in memory then its not expandable. Some of them are expandable but you need the specific memory chips to be added to the card.Also There are Some Motherboards which Significantly Change the Capacity of VGA When you Increase Your Ram. It depends on which motherboard does your lapotop has.
Answered By 10 points N/A #99064
 I agree with you.
 First I need to make sure about motherboard before doing this. Thanks for your time.
