paulartney
1290 points
Posted on - 07/18/2011
Hi! People,
I am sharing here a scenario that I experienced, while using my computer, an error message appeared on my computer frequently, the error message tells me that DiskAction2.exe has been terminated because it was deemed harmful by Active Virus Control.
Control.
I pasted the above context of the error, for you to refer, as I picture out on the error, its is referring to a file that is harmful, I always get this error, I am wondering what this error message means, I did not make any moves, because I am afraid what might happen to my computer, please share some ideas on this.
It was deemed harmful by Active Virus
Dear Paulartney
The error message Diskaction2.exe has been terminated because it was deemed harmful by Active Virus Control appears when non systematic process within the computer operation is stopped since they are automatically operating by some users for the most of the time. This process produces more system garbage during their operation. You are advised to stop diskaction2.exe immediately.
You can use Windows registry cleaner to scan and clean your registry files. Download Regt Weaker software for registry cleaning by clicking on it .Recommended Action: Fix diskaction2.exe Related Errors
Hope your issue will be settled.
Benth
I have a really easy solution. You should go to the options and then click the ''Advanced Settings''. A requestor will pop up. Then you will recognize the DiskAction2.exe and click remember. The problem will not come up again. This worked for me. Now, if this does not work for you should get in touch with DiskAction2 service or "Active Virus Control". Moreover I would like to suggest you to download the third version of DiskAction as it has much more features that the second one.
