Abrianna
60 points
Posted on - 11/24/2014
We all know that Oppo is always not like the other Chinese phone manufacturers and their target is only the mid end to high market. Now their flagship N1 device which has several unique features also a unique swivel camera. My only doubt is that Is it worth buying Oppo N1 mini phone which is priced at Rs.26,990/-?
Is it worth buying Oppo N1 mini phone?
If you are having second thoughts on buying the Oppo N1 mini Smartphone, I guess you shouldn’t have to. Here’s why. The Oppo N1 mini Smartphone supports 2G, 3G, and 4G networks and uses a SIM card. It was unveiled and released on August 2014. It measures 148.4 x 72.2 x 9.2 millimeters and weighs 150 grams.
It has an IPS LCD capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution. It supports multi-touch with Color OS 1.4. It runs on 2 GB RAM with 16 GB internal storage but it doesn’t support an SD or microSD card. It supports Bluetooth 4.0 and microUSB 2.0 with USB Host.
The primary camera supports 13 megapixels at 4128 x 3096 pixels with LED flash and autofocus. The camera features 1/3.2'' sensor size, geo-tagging, touch focus, rotating lens, HDR, face detection, and panorama. It can record video in 1080p at 30 fps. The secondary camera also supports 13 megapixels with LED flash and autofocus.
It runs on Android 4.3 Jelly Bean powered by Qualcomm Snapdragon 400 chipset, Quad Core 1.6 GHz Cortex-A7 processor, and Adreno 305 GPU. It has accelerometer and proximity sensors and supports HTML5. It supports GPS with A-GPS and Java. It runs on Li-Ion 2140 mAh battery.
