Hello people. I have bought Microsoft Office 2010, and there' s only one key.
I downloaded Ms Office in English, and I wanted proofing tools to be in another language, but I had to pay for that!
Is it possible to have English interface with proofing tools in another language?
I would download Office in my language, but I'm used to use the English version.
I just want the proofing tools in my language.
Italian Proofing Tools in English Office –
For this purpose do the following steps:
To change the language of a document to check the spelling, do the following:
1. Place your cursor in the file where you want to start typing text in a different language or if you have already typed the text, select the text.
2. On the Review tab, in the Language group, click set Proofing Language.
3. In the Language dialog box, select the language that you want.
4. Start typing.
Note: you might need a language pack to if your version of office does not provide proofing tools, such as the spelling checker.
For language pack see details here:
When you will install Microsoft office then in that case you need to select the language. You can choose the language of your choice. If this does not solves your problem then in that case you can select any of the language translator that you will need to install. Generally, if we have to type in other language the we have to add that particular font  in that language. Once you do that then you can type in that particular language and also proof read.
Waters Magner
