Hi Guys I am using window operating system now I am trying to create one text file or Microsoft word file for this I open Notepad or Work then I type some data in it after typing now I want to save that file but when I click at save button then this error appears.
Also almost save forward.
All error detail is given below.
The item “sample.txt” cannot be written, because a disk error occurred. Do you want to continue?
Stop Continue
You did not mention where were you saving your work file.
If you are going to save it on a floppy disk, the disk has a problem.
Fix it first using Scandisk or the Tools option.
Insert the floppy disk on the floppy drive. Right-click drive A on your Windows Explorer and choose Properties.
Click on Tools tab.
Under Error checking, click the Check Now button.
Click on the 2 checkboxes then hit the Start button. Wait for it to finish.
Now, you can try saving your work on the disk.
If the error is still there, replace the floppy disk with a working one.
