Itunes-purchased but balance is the same
Recently I have purchased some I-tunes with my debit card. I checked the balance after that but it seemed to be unchanged. I do not what happened. Whether it will be taken later or it is a mistake. Will this cause me further trouble later? If so, then how to solve it? Kindly let me know about the solutions.
Jovan Clayton
Answered By 15 points N/A #117071
Jovan, when did you purchase the software and when did you check the balance? There is normally a delay of 3,4 days till your balance gets updated on the bank statement. If there has not been enough gap between the two events, then i must say that you should wait for a couple of days and recheck the bank statement. If it has been long enough, then what you can do is to get in contact with your advisor in your bank and tell him the situation. It will make sure that you are on the safe side as you reported the issue to the bank. Before that, just verify the cost of the software that you bought. May be it was just an update to your previous software and it was free so you did not have to pay any thing?
