I recently downloaded iTunes, and since when turning on computer I receive an error message “Entry Point Not found”.
How can I fix this issue?
Guide me step by step please.
The procedure entry point_CFBundIeCopyFileTypeForFileData could
not be located in the dynamic link library CoreFoundation.dll.
ITunes cannot find entry point
You can fix your iTunes issue by first of all uninstalling it.
You can then download it again from a trusted site such as Apple and re-install it again.
Be very keen when downloading as there are versions that you may download and turn up not to be compatible with the Windows that you are using.
For instance, Windows 7 may refuse to download iTunes version 10.3.1.
Hi John W Griggs,
The problem lies in your photoshop.exe not on your iTunes, iTunes has nothing to do with it, you just have to try to reinstall the Photoshop because your library files are corrupted and can not be accessed by it.
