ITunes could not complete iTunes Store request.
I have checked my Internet connections and everything is working just fine. The problem is iTunes because is not working due to network connection. This is my first version of iTunes and also the first time when I want to use to connect with my iPad Mini. Why the iTunes cannot connect to the Internet ?
My Internet connection is working just fine.
Thank you !
We could not complete your iTunes Store request. The network connection could not established.
Answered By points N/A #171460
The following steps describe the techniques to solve this issue.
  1. Start iTunes.
  2. * From Windows PC:
    Go to Edit menu >> Preferences
    * For Mac OS X:
    Go to iTunes menu >> Preferences
  3. Open the “Parental Controls” tab.
  4. Place a checkmark beside to the option to disable iTunes Store.
  5. Do this again to the option “Allow access to iTunes U”.
  6. Click “OK”.
  7. Once again, go to “Preferences”.
  8. Uncheck the option to disable iTunes Store.
Now your problem should disappear for good.
Answered By 590495 points N/A #307963
If you receive that error when using iTunes, first, make sure you are using the latest version. Download the latest iTunes and install it to upgrade your existing version. The latest version at the moment now supports Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit. iTunes dropped support for Windows XP and Windows Vista.
After updating to the latest version, try it again and see if it works. If this doesn’t work, check your internet connection. If you are using iTunes on a computer and you are connecting to the internet via Wi-Fi, check your Wi-Fi router. Try resetting it.
If the Wi-Fi router has a power button, press it to turn it off then unplug it from the power for about 10 to 20 seconds. Press any button on the router to drain any leftover power and to power cycle. After this, plug the router back to the power and turn it on.
When the router is ready, try connecting your computer to the internet again and see if it works. If you still can’t connect to the internet via Wi-Fi, try connecting your computer to the router using an Ethernet cable or LAN cable. See if this works.
