ITunes could not connect to the iTunes Store
This morning this error appeared and now I cannot connect to iTunes Store. Yesterday everything worked fine and now I cannot connect to the Store when I need it the most. Can anyone please help me to fix this iTunes error? Why is not working now?
Thanks!
iTunes could not connect to the iTunes Store. An unknown error occurred (-3212).
Answered By points N/A #171335
This error indicates that iTunes is unable to contact with gs.apple.com server on ports 40 or 443. So, iTunes is throwing up the error.
You can easily fix this issue by configuring your firewall. Possibly, your firewall is preventing the software to access internet. Allow your iTunes to be accessed on internet. Otherwise, you may disable your firewall program for a few moments.
Also, updating your iTunes should be better. Download iTunes.
