ITunes will not synch iPod photos. I get an error message "could not be synced because the sync session failed to finish"
Optional Information:
Computer OS: Windows Vista
Browser: IE
Already Tried: reboot. Reinstall iTunes. Moved photos to different directory.
I am totally confused. Please help.
Thanks in advance.
ITunes does not synch iPod photos
The problem may occur if you have too many photos. One of the way to solve this by selection one folder at a time. You can also try to solve this problem by restore your iPod. But before that you can follow the steps:
Edit > Preferences
In the device tab click on “Reset Sync History”
You can also follow the below steps to solve it
With iPod plugged in close your iTunes
Wait few more moment
Open your iTunes
Now try to perform synch
If you have a problem with iTunes, don’t just reinstall the application. That will do no good. iTunes is one of the programs that is very common to cause errors. And when you encounter one, reinstalling is a bad idea. The best way to deal with it is to install the latest version. First, download Revo Uninstaller Freeware 2.0.0.
Follow the instructions to download and unpack and then install it. Once installed, run Revo Uninstaller, select iTunes from the list, and then click “Uninstall”. Follow the instructions. After uninstalling, restart your computer then download and install CCleaner. Once installed, start CCleaner and clean your system. After this, go to Apple iTunes Download then download and install the latest iTunes.
See if this works. If you want to register CCleaner, download CCleaner Registration Codes and follow the instructions.
