Hi, my iphone is showing some sort of problem. Yesterday when I was trying for restoring it to the 5.1 the screen showed iTunes error 9. I uninstalled the program through my pc and then reinstalled it but the problem persists. Can you give me any kind of solution for this problem? Thanks.
ITunes “error 9” after restoring iOs
Error 9 on iTunes is a USB error. This error usually occurs when the iPhone got disconnected during the restore process.
Here are some ways which can help you in fixing iTunes error 9
*Try using a different PC or Laptop or a different USB cable or dock, make sure that you are using the original cable which is included on the iPhone device .
*You can also try a different USB port on your PC like the ports that is located at the back of your CPU.
*Don't use a USB hub or any extensions as well.
*Gently cleaning the USB connector at the bottom of your iPhone might also help.
*Check for USB driver updates on the internet.
