Hi experts,
I am getting the following error message when running the iTunes software:
iTunes was unable to load provider data from Sync Services. Reconnect or try again later
iTunes was unable to load provider data from Sync Services. Reconnect or try again later.
ITunes error.unable to Sync services
If you are experiencing problems when synchronizing your phone with iTunes, try checking if you have a good signal. A very low signal can interrupt data transfer between devices and can cause the process to suddenly stop.
Try restarting your phone and then try again. If you are connecting your phone to the computer using a USB cable, try transferring the cable to the other available port and then try synchronizing again. If it still does not work, try uninstalling your phone software from the computer then check your computer for any possible errors.
Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities or PC Tools Performance Toolkit. After the disk check, install the phone software again.
After the installation, restart the computer so you will have a fresh system when you try synchronizing again. After booting the computer, connect again your phone to the computer and then open the phone software on the computer. If you still get this error, maybe the server is busy. Try doing it again later.
Hello, i think you need to download the latest update available on your apple itunes store, make sure that you download the latest version of itunes on your computer, or you first have to uninstall quicktime, apple mobile device support,apple software update and lastly the itunes.
Then after that reinstall all this software that you need in order to synch on your apple application, go to the apple website and install the latest itunes version for your computer and synch it to your other apple products.
You also need to update your itunes so that it will be compatible on your computer system, Apple itunes can be download for free on the apple website there you can check out for the latest on itunes.
You can download some free stuff for your other apple products but most of them you need to pay for like downloading songs or movies or software application which can make your apple experience enjoyable.
Thank you Sharathr and Waguna lorna. I reinstalled my itunes and updated it. Now the error is gone. Many thanks TechyV.
Hello Jeffrey
Besides these solutions also visit this Techyv page to get another technique to resolve this issue easily.Â
ITunes was Unable to Load Data
