iTunes failed installation causing problem
Hi friends,
I bought the apple gadgets like iPod and iPad, so I am trying to install the iTunes in my system. When I tried the installation went well and good without any error but the error pop up stating the installer encountered error before iTunes could be configured. What might be the cause? I tried again by restarting the system and re-installing iTunes, no luck. Anyone experienced this before, suggest me some solution. Thanks.
Error:
iTunes Installer Completed
The installer encountered errors before iTunes could be configured.
Errors occured during installation. Your system has not been modified.
Please run the installer again, or click Finish to exit.
Answered By 590495 points N/A #188524
Before installing iTunes on your computer, make sure your system is compatible with it. To be able to install and use iTunes, your machine should be running on Windows XP, Windows Vista, Windows 7, or Windows 8 and it should be in 32-bit. The version that is available for download on the website is the 32-bit version since this is the version mostly used.
If you have a 64-bit operating system, you should also download and install the 64-bit version of iTunes. If you downloaded and installed iTunes from its home page and this error happens, then maybe you are using a 64-bit operating system making it incompatible with the application. To download the 64-bit edition of the installer, visit iTunes 11.1.3 for Windows [64-bit].
Once downloaded, you can begin installing it right away. See if this fixes your problem. For users who want to download the usual 32-bit version, visit iTunes 11.1.3 for Windows.
