Go to start>>control panel>>user accounts >>create a new user account that has admin in the new user account try to install iTunes for all users. If it installs, log out and go to your usual account, check you have access to iTunes and can use the program, set it to find your music and create the library.
Once your happy its installed and fully working you can delete the spare user account that you made.
According to a post in the Apple forum, error code “450” can be associated with the Parental Controls in Windows Vista. This affects downloads from the iTunes store. So, if you are using Windows Vista and you keep receiving error “450”, you need to add the following URLs to Parental Controls’ safe list:
https://www.apple.com/
https://www.apple.com/itunes/
To do that, in Windows Vista, click “Start”, “Control Panel” then under “User Accounts and Family Safety”, click “Set up parental controls for any user” and then select your user account. On the next screen, under “Windows Settings” section, click “Windows Vista Web Filter”.
On the next screen, under “Allow and block specific websites” section, click “Edit the Allow and block list”. On the next screen, enter the addresses listed above one at a time then click “Allow”.
Enter allowed websites
And that’s it. Now, try downloading your songs again with iTunes and see if it works.
1....
