Itunes : Installer has Insufficient Privileges
Greetings, TechyV!
This error is a rummy one, and I can't figure out what's wrong.
I'm using Administrator privileges,but ITunes insists on this error every time I try to use it.
Should I un-install the whole thing or is there something to modify in my access?
A little help would go a long way, thanks!
ITunes + QuickTime
The Installer has insufficient privileges to modify this file: C:Program FilesiPodAcknowledgements.rtf
