ITunes on IPhone 4 Doesn’t show.
I have IPhone 4 and ITunes does not show the ios 5 update.
Many times I re install the phone, but the result was the same.
Need your help guys.Â
The Apple iPhone 4 runs on iOS 4 originally and can be upgraded until iOS 7.1.1. If you are not receiving any update or you are not receiving the iOS 5 update when using iTunes, I guess the problem is not with your mobile phone but with iTunes itself. If you haven’t updated iTunes yet, update it now. Visit Download iTunes Latest to get the latest version.
For Windows users, this is the 32-bit installer. If you’re on 64-bit Microsoft Windows, visit iTunes 64-bit to get the 64-bit version of the installer. Once downloaded, uninstall your existing version. Click Start, Control Panel, and then Add or Remove Programs. Select iTunes from the list then click Uninstall or Remove. After that, open Windows Explorer then navigate to the download folder.
Double-click the iTunes installer you just downloaded to install the latest version. Once installed, connect your iPhone to your computer then start iTunes. Try checking for any iOS update again and you should be able to receive the latest iOS version applicable to your phone.
