Hello
I have suffered ITunes Match problem. My uploaded tracks were not streaming and downloading problem in iTunes. Give me a solution.
"There was a problem downloading ""You Can't
Always Get What You Want / Hot Rocks
1964-1971/ The Rolling Stones"". An unknown
error occurred (-2114).
Please check that the connection to the network is active and try
again"
ITunes Match problem – Looking for Solution
Dear User,
This could be a problem of your network connection. First make sure you are connected to the internet.
If you are connected and still getting the same error,
Please try re creating your iTunes library and playlists.
How to re-create your iTunes library and playlists
After you have done recreating and when you turn iTunes match on, it should probably work
And also I recommend you to make sure to disable your internet security applications if you have any , until you sort this out,.
Thank you.
