ITunes not able to sync music from Ping.com
Hi experts
I keep on getting the following error message:
iTunes was unable to load provider data from Sync Services. Reconnect or try again later
.png)
I need your help to solve this.
Please help.
Hi experts
Please help.
Hi you may want to try this solution for your problem.
First you would need to make sure that you have the latest version of iTunes installed.
This way you know that your device is supported by the new version of iTunes.
Then follow these steps.
(Note: You must have Admin rights on your computer.)
1. If connected, disconnect your device from the computer.
2. Open iTunes and navigate to the EDIT menu.
3. Choose Preferences then click the DEVICE tab.
4. Click the Reset Sync History then reconnect your device.
Hope this solves your problem.
Your problem occurs from using iTunes on Windows. To troubleshoot connecting your iPad, iPod or iPhone, make sure you have access to the administrator account on your computer.
Do you have the latest version of iTunes? If not get it from here, latest version.
You have to reset your sync history as follows:
If this resolve your issue, then do the following to sync your device:
If the issue persists and you know your data are on your device, do the following:
Unplug all devices
Unplug all USB devices except for the IOS device, keyboard and mouse. Restart your computer and test.
Check your security software.
Do the updates and reconfiguring. Follow steps in iTunes for Windows Software troubleshooting. If needed, disable and test. If the issue persists, check your security compatibility.
Resolving Windows Sync
Lastly, if the issue persists, create a new user account on Windows to check if the issue is due to account user. Try to sync your device using the new account. If this resolve your issue, try to follow this troubleshooting article link to resolve user account issue, "If you are able to sync while logged in with a different Windows user account".
Notifications
