uiquey
Posted on - 03/20/2012
Hello all,
I’m getting iTunes error "iTunes was unable to load provider data from Sync Services. Reconnect or try again later." and unable to make sync to my iPhone Please help me with right direction.
Help would be appreciated greatly.
ITunes was unable to load provider data from Sync Services.
Firstly try to install new version of iTunes and connect it with your iPhone. Immediately  you will get error message, from there you go to  the Help menu and click diagnosis. Check the Connectivity Test and Test of sync with the iPhone and then start the diagnosis. Unplug the iPhone, then reconnect it while keeping iTunes open.
Hey,
I am also a user of IPhone. I faced this message many times but luckily I succeeded to overcome the problem. I searched on the internet but did not got any good solution that could help me. Then one of my friend told me that how to overcome this problem. It’s really very easy to get rid of this problem. Mostly windows 7 users face this problem as I am also a windows 7 user that’s why i was facing it. Anyways what you need to do is just to follow these steps.
1. First of all unplug your phone from the data cable.
2. You have to rename the folder "SyncServices. Go to: C:Users<username>AppDataRoamingAppleComputer to SyncServices_Old
Note: The username in the brackets will be different according to your windows setup.
3. Once you rename this folder, now reconnect the Phone.
You are done.
Thanks
To solve this problem first of all check that you have a good signal, low signal can interrupt data transfer as well restart your phone and then try again. Here indicated all solutions are good but Techyv has another post where you will get more information regarding this issue. Go this page and get more information.
ITunes error.unable to Sync services
