Disable temporarily iTunes from syncing iPhone automatically
Posted on - 08/27/2011
I want help with this small question. I need a way to switch off the auto detect of my iTunes.
I plug it in 10 times daily and each time I just connect to charge it and not sync. Where are the settings, to shift to, don't detect and sync or check for updates?
Thank you for your time
