I’ve got some error of installation in XP
I've got some error of installation in XP. It could not perform because of an device error. Can someone help me with this problem? Please help me.
Here I would suggest you the solution. Try this:-
"Â Â Â Â Â Â Â Â Â Â Hit shift+F10 to get to DOS cause.
"Â Â Â Â Â Â Â Â Â Â Type "sysdm.cpl" which give train you to the method covering.
"Â Â Â Â Â Â Â Â Â Â Click element tab then devices to take you to instrumentation recite.
"Â Â Â Â Â Â Â Â Â Â Locate your cd push and it may off a yellowish error symbolization over it.
"Â Â Â Â Â Â Â Â Â Â Right utter the cd push and move properties.
"Â Â Â Â Â Â Â Â Â Â Click the driver tab and penetrate update driver.
"Â Â Â Â Â Â Â Â Â Â Choose place utility from circumstantial location.
"Â Â Â Â Â Â Â Â Â Â Click don't seek i present decide.
"Â Â Â Â Â Â Â Â Â Â Choose the rattling prototypic generic cd wood on the name occlusive "next".
"Â Â Â Â Â Â Â Â Â Â Then restart.
You need to check all of your hardware to make sure that there is no problem in your hardware. Specially you need to make your disk error free to run a new window on it. You can check you hard disk by going to cmd and then you need to run cmd and then by chkdsk it will check your disk and will make it error free. If you are not getting some output on screen then this may be some other error and you need to check you all of the components in this way to check that you have all the required info that is necessary to solve your problem.
Once you have checked all of your computer components you will be able to install your window. To install new window just put a CD/DVD in your computer and then you will be able to install your new window.Â
