THE IVY BRIDGE-BASED MICROSOFT WINDOWS 8 ULTRABOOK SHOWN BY IN BRAZIL
The Windows 8 Ultrabook with touch screen functionality would last till 10days standby without charging because it's 20x less power how long the warranty would last?
Hi Athan,
The new Windows 8 Ultrabook is powered by the new Intel Ivy Bridge Processor. This new processor is from the 22nm third generation processor of Intel. Ultrabooks and desktops with Intel Ivy Bridge on it, efficiently manages power by, using 20x less power from the battery.
Enabling the user to enjoy more hours of use of their computers and tablets. Like all Intel products, ivy bridge is covered by its warranty rules.
The warranty of the OEM Version of this processor depends on the manufacturer or supplier of your computer system. Make sure to check the warranty documentation that came with the system for full information. While, the Boxed version of this processor is under Intel's limited warranty of three (3) years.
Hope this will help you!
The modern Microsoft windows 8 Extra book will be centric by the brand new Intel Ivy Connect Processor chip. That brand new processor will be in the 22nm next creation processor regarding Intel.
Extra ebooks and also desktops having Intel Ivy Connect about it, successfully handles strength by means of, making use of 20x much less strength in the electric battery.
Enabling the consumer to savor more time of use of these personal computers and also supplements. Just like just about all Intel products, ivy connection will be included in its warrantee rules.
The warrantee with the OEM Variation in this processor depends on the software creator or even provider of one's laptop or computer technique. Always check this warranty paperwork in which had the system for complete details. Whilst, this Boxed type in this process will be within Intel's limited warrantee regarding three (3) many years.
Hope it helps you.
