Ian M Tyner
10 points
Posted on - 06/24/2013
When I share a copy of an iWork document to iWork.com the following error message displays. I tried again and again but same error message disturbed me badly. Any help would be really appreciated.
Thanks in advance.
Error Message: An error occurred when uploading your document. Please try again.
IWork – Error while uploading a document
The error message “An error occurred when uploading your document” while sharing your iWork documents to iWork.com may occur in any of the iWork applications.
This dialog message may appear due to the reason that the name of the document that you are sharing may be too long or not acceptable. You can try again by changing the name of the document, and will be able to share document.
