IXLA WebEasy Software for Creating Web Pages
Hi guys,
I want to create web pages by myself. I know that there is ixla web easy program. However, I am not familiar with it. Is there any one can help me by giving systematic instruction?
Thanks
Hi guys,
Thanks
Hi Mcleod Holcomb
ixla web easy program allows you to design and publish your own website, you can build a website less than an hour with step by step process.
If you have a problem you can get help from activity center. That will guide you to make good designs, import pictures & background images.
And you can use online library of pictures, clips, backgrounds, animations, buttons, and banners.
For this you do not need any programming knowledge & this will automatically generate HTML code & that will work with all internet browsers.
Thanks & Regards
MckinneyMa
Hellow Mcleod Holcomb,
I am giving procedures how can you get self trained of ixla web easy software.
Thanks
Shifflett Laurel
Ixla WebEasy is a kind of software product which provides you as a novice users to build personal or small business websites in a minutes with photos/ graphics as well a wizard-style interface.
You can add text, effects, audio, and video as well as animated objects. Importing photos from scanners plus digital cameras has also an opportunity.
It supports HTML, DHTML as well as VRML. It is a program that you can usage to make web pages without having any knowledge how to do HTML or anything like that. Now this software is available in a reasonable price in today’s market.
