Java applets not loading? Do I need to update something?
I have a problem using Java, I tried to use Java applet but it says unable to run java on our system,
I tried it again, and now it says, "Active x being disabled" What do I need to do?
Good Day Vanessasales,
If you have problem in opening java applet and saying “ unable to run java” on your system, otherwise “Java/ActiveX being disabled”, Please Java Problems to solve your problem, it will help you to fix the said error. If you unable to load applet, you must need to download a modernized version of Microsoft VM from here:
Now, if you still have that errors after you follow the instructions above, visit the link here. Post your concern on their forum, where will they answer as soon as possible.
This is allowing us to trace your exact problem
I hope this information helps,
Mark Amna
