Java based consumer web service for creating Java Agent Calling
I created a java consumer web service. This web service then, created a Java Agent Calling. Then the Java imported by the Web Service Consumer. I describe the web service system just like in the java agent method. Below is a sample result of the number of data gathered from the web service. The web service process only returns documents based from its time stamp. I expect that it will only return one (1) document from the next identified web service but it also includes the documents previously gathered by the java agent. I tried using JAX-WS and Apache Axis 2 and as expected it works in software UI. Is there any reasons why notes create catching of results? Is there a way to disable catching if it appears?
