Java encounters error, cannot load Snaptu
I use snaptu software in my Nokia X3 mobile. This has happened about 4-5 times in the last couple of weeks. I install snaptu fine (unsigned) reorder home screen to my apps etc, works fine for about 4-5 uses then get an error from Java when starting saying it encountered an error, doesn't say what.
If I uninstall and re-install snaptu again and keep my data I get same error, if I don't keep data it starts as if fresh install.
Anyone have any ideas?
Best Answer by Bfinch Marian
Answered By 5 points N/A #96049
Hello, first of all you need to uninstall snaptu from your device and download snaptu and setup again.
You can also download this program here.
Sometime it happen when you download this software from snaptu homepage then it show this error so just click the link above to download it.
Answered By 0 points N/A #196100
Hi Paul Adam,
I think your error is an out of memory error. Snaptu application use some memory of your phone to run. After you install Snaptu you can use it without any errors because, there are no many temporary memory usages. After you have used Snaptu several times, it will have some temporary memory in your phone memory, so if your phone memory haven't enough memory to run Snaptu, it will give you an error. Memory means like a RAM of your computer there is a temporary memory inside your phone to run your applications. I have the same problem with a game. Hope you can get some idea about your problem.
Enjoy!
