Java fails to open the attached device
Suddenly this error appeared on my desktop. I didn’t changed anything in my system that could cause this. Should I be worried about this error ? What is causing this error ?
Thank you experts !
B:UsersRobbieDesktopJavaRaJavaRa.exe
A device attached to the system is not functioning .
Answered By 590495 points N/A #179152
Kindly check the version of JavaRa installed on your computer. If you are using an old version then it is more likely that you are using the version that supports Windows 95, Windows 98, Windows 2000, Windows XP, and Windows Vista. So, if you are using Windows 7 or later operating system, you will not be able to use it.
To fix the problem, download the latest version, JavaRa 2.6. It requires Windows 2000 x86 only, Windows XP x86 only, Windows Vista, and Windows 7 both x86 and x64. See if this fixes the problem. For those who do not know, JavaRa is a very simple tool that lets you update and or uninstall older versions of Java Runtime Environment [JRE].
