Java Installer Error when Updating Java
Hi All,
I get this when i try to update java
Error – Java Installer
Unable to download http://javadl-esd.sun.com/update/1.7.0/1.7.0_10-b11.xml for installation.
OK
thanks
Best Answer by Fenster Maxine
Answered By 5 points N/A #161565
Hi User,
I found the you face lot of problem in java updates. This error is occurred when there is any problem in Internet connection or very slow connection.
I am providing the java link, where you can download the latest version of Java as per your system requirement. Download Setup file from below mentioned link :
https://secure.dofus.com/en/mmorpg/play
You just download and install, there is no need of update.
I wish this solution may be helpful. Thanks!
Best,
Fenster Maxine
Answered By 0 points N/A #161566
Hellow  Saa222,
I have grasped about your problem. Now I am giving possible solution for saving the installation file to update java.
Firstly you have to select all of the contents of the file. Then copy it and paste to notepad. Save it with exact file name as given. Save it to the update library of java .Then update java again.
I hope this will be helpful for you.
Regards
Shifflett Laurel
Answered By 590495 points N/A #161567
I think this problem is in your Java application and will always appear every time you try upgrading it. This is sometimes due to the fact that the server where the application is set to fetch the update file for the program is constantly changing and the URL indicated in the xml file to fetch the update file no longer exists due to updates made to the website where the update files were possibly moved to a different page or location. And I think this is the main reason here why you are receiving an error in the xml file.
Every time this error happens to you when updating any application, the next best thing to do is to visit its official website and download the latest version manually. Since you are updating your Java application, the best work around for this problem is to visit ORACLE® | Technology Network | Java | Java SE Downloads and then download the latest version applicable for you.
