Hello Friends,
I will be visiting blogs and study web forums to check for my unsolved issues. I take help from the online experts and solve my issues. Recently, I had opened a web site and it is asking for some digital certification, which I did not encounter till date. It also says that Java is not installed. But to my knowledge, I had installed the software in my system.
I kindly request the experts so solve my issue ASAP so that I can continue with my work.
Java is not installed in the system
Hi Dear,
Thanks for sharing your problem with us.
Dear if you have installed java already in your system then why it requires java from you. It seems that you have installed an older version of java or your java program has been crashed.
I suggest you to install the latest version of java.
You should use Java version 7.
You can download it from this link.
http://java.com/en/download/index.jsp
I hope it will helpful to remove your problem.
Thanks
Hello Dear,
You think that you have installed it, but your system says it requires the software. This means that you have installed an outdated version of Java. Java is a very important utility and plug in for viewing specific information on the internet. I suggest you use Java version 6.0. It will remove this problem permanently. You can download Java from this link.
https://en.softonic.com/s/free-java-6.0-32-bit/windows-xp
