alfonso ty
Posted on - 04/17/2012
Please advice what could have been wrong with my Prime Tool. I have installed the latest version of Java already but it keeps on saying that I need to install the latest version of Java.
Anyone here who happen to have a similar experience before?
Where you able to fix it?
Please assist. Thank you.
Java requirement for Prime Tool
The costs of implementing have but also organized series customers back. The resources necessary to be tell to use the environment. Therefore the necessary effort to create and set up a proof-of-concept program that can handle the financing to instructor designers proven expensive in terms of expenditure and time. for example, before could, IBM Web Sphere program host was necessary to set up Coffee.
Web Sphere was going through fast variation and was usually difficult to apply. Additionally, you necessary to get PC-based progression resources that might price quite $3,000 per creator.
Hardware requirements: A computer program with a Pentium method, System
Java support program: – Applets, Servlets, EJB, JSP, XML,SOAP, CORBA
Thanks
