Java Runtime Environment Error 2753
I can't seem to run any P2P programs. It keeps telling me to upgrade my Java Runtime Environment to latest version. But mine is Version 6 Update 26. For all I know, this is the latest version from Java. And my Windows XP keeps reminding me if there is an available updates for every software or application installed on my computer. Anyway, I go to Java's Website to check if there is a newer version, but the version I have is the latest update from them.
So to make this work, I uninstall it first, then re-install again to ensure that all the components needed for it to work properly will be downloaded again, just in case I miss out something. But it still didn't work. I turn the computer off then uninstall again, but I was unable to do it for the second time. I get an error 2753 from Java Setup.
The content of the error is;
Internal Error 2753. Regutils. dll
It seems to me that my Java is corrupted or something. But I don't understand what it has to do with the registry. I run the Cleaner and fix everything, but it is still the same.
Can someone here help me on this?
I am running Windows XP Service Pack 3.
Please help.
