Java Runtime Error – How To fix Java Runtime Error
30 points
Posted on - 08/14/2012
Hello TechyV buddies!
I am having some problems that I encounter in JAVA script.
This is the error message that I encounter:
“Java(TM) Plug-in Fatal Error
Several Java Virtual Machines running in the same process caused an error. ”
“Java(TM)Plug-in Fatal Error
The Java Runtime Environment cannot be loaded. ”
Can you tell me what to do with this kind of error messages in Java if ever I encounter them in the future? I would greatly appreciate the effort in helping me solve this matter.
Thank you.
