CS3 install Java Script with error. I have downloaded the installer from different sources and the error is the same like this one showed below. I don’t know what could be the problem. Is there a problem with the installer or with my laptop ?
Thank you !
JavaScript Alert
Critical errors were found in setup. -The installer database is invalid: Please re-install the product from the original media. Please see the Setup log file for details.
Java script alert with critical errors found
When installing Adobe Photoshop CS3, make sure your computer meets the requirements. Since you are using Mac OS X, you need to have Mac OS X 10.4.8 Tiger until 10.5 Leopard for you to be able to install Adobe Photoshop CS3. If you have Mac OS X 10.6 Snow Leopard or higher then you can’t install Adobe Photoshop CS3.
Install a much higher version such as Adobe Photoshop CS4 and later. To make sure the installer you are using is really a working installer, download Adobe Photoshop CS3 for Mac. Scroll down slightly to the middle of the page to find the table where you can download a legit copy of Adobe Photoshop CS3. See image.
If you want to download JRE, download Java SE Runtime Environment 7u67.
