Java script and Vb script
What is difference between Java script and VB script ?
Best Answer by Harrington Curtsinger
Answered By 0 points N/A #177934
Hi, Shekharsirohi.
In comparing these two languages, they have many differences in their both sides. VBScript only runs with the use of Internet Explorer. While JavaScript code will run in any of the browsers available. And when it comes to their coding formats, VBScript has used of Function and End Function to determine that it was a function. While in JavaScript it only used curly braces to every functions. Actually, there are plenty of differences about these two languages. Like, concatenation of text their file extensions, and VBScript was developed by Microsoft while JavaScript was developed by Netscape. Hope this will help you comparing both languages.
Best regards.
Answered By 0 points N/A #177933
Hi Shekharsirohi.  I think, the problem with your website is not the zoom but it is the pixel.  Try to check again your website settings and check your pixel resolution. If it is too big, try to resize all the images and fonts including your website backgrounds. You can do trial and error procedure so you can make your website perfect. I hope this information helps.
