An error occurred after installing the new Java updates available.
It has shown an error after the installation which I could not understand and there has been this problem with PC slowing down.
I can't think of any method of solving it.
Kindly someone help me with the problem.
Java update compatibility error – error occurred after B15844installing
If the installation of the update for your Java application has failed, try restarting your computer then try it again. If it fails again, try downloading the new version instead of going to the update wizard or the update button to update the program. After downloading the new updated version, install it.
This will cause the new version to upgrade the currently installed version.
But sometimes, other application’s way of upgrading is to automatically uninstall the currently installed version and after uninstalling it, it will then proceed with installing the new version. Any of these procedures doesn’t matter as long as the program is upgraded.
If your computer is beginning to slow down, try defragmenting your hard drive. It is possible that your hard drive is heavily fragmented that makes applications to load very slowly. But before defragmenting your machine, check first your computer for any possible errors. Use a disk utility application to check the system.
It’s a best practice to check the system first for errors before defragmenting the hard drive to avoid any damage to the system.
