IrenaSz
Posted on - 10/19/2011
Nice to meet you, TechyV people!
When I connected to a server, a Java applet was downloaded. But this error interfered and the applet could not be run.
I tried refreshing the page a couple of times but got the same result.
Anybody have ideas about this one?
A lot of thanks for any suggestions!
Java(TM) Plug-in Fatal Error
The Java2Runtime Environment cannot be loaded.
Java2Runtime Error: Cannot be loaded
Hello IrenaSz ! Have you tried to reinstall Java Sun? Or should I say do you have Java Sun installed in your computer? Well if not, you need to download in java.sun.com and make sure to download the one that is for your OS (Example: Vista or Windows). After downloading and installing it, you need to reboot your computer. And then when you reconnect to the internet Java update will pop up. Just follow the instructions on how to update Java. If you done all this, I'm pretty sure that you will be connected to Java server. Have a nice day!
Kelvin
This the impossible solution to your problem, first thing you must do is trying to launch the Internet Explorer or any Browser that you use, and then from the java bin directory there a path declaration that comprises, after that just simply launch the browser from the your command prompt.
• Go to start menu
• Select the search program and files
• Type this code :cmd
• After that you just simply type another code: set path=C:jdk1.3.1_09jrebin;%path%
• Then type another code: cd C:Program Files Internet Explorer
• And then type another code: iexplore.exe
Makes sure that the browser must start normally, and then after just simply reboot your system if it’s possible.
Ben
