I defragged my computer for faster performance and to get rid of the Auto-Restart. Then, this morning I come to play with my friends online and listen to some Music. So I search “Inspector Gadget Dubstep” I noticed no suggestions came up on Youtube, so I opened the video than it said I needed Adobe Flash Player.
I have both, I just updated Java, and now I'm getting bored. Can someone give me a hand with this?
JavaScript and Adobe Flash Player won’t work.
Hi
I will help you to get your Flash Payer work. You are saying that, you got rid of Auto-Restart. What do you mean by Auto-Restart ? Because, there is no such thing pre-installed. Another cause of Flash Player and JavaScript not working could be some of your files may be missing. Try installing them. If not working, then try installing your browser. Also check different browsers as it could be an issue with a single browser.
Thanks experts for your informative suggestions. Emil Onoon, your suggestion made a lot of sense to me. I am sure you have the perfect solution to my problem. When I followed your instructions and installed my browser, my problem disappeared. I am very grateful to you, my friend, for giving me such a nice solution. As a result, I no longer have any problems with Adobe Flash Player, and am able to enjoy all the music I want.
