JavaScript Execution Throws 800A1391 Error
Describe the 800A1391 error? Why 0xc004f00f error occurs and describes the methods to resolve the error?
Code 800A1391, commonly known as Javascript Error Code 800A1391, described as Error 800A1391: JavaScript has encountered a problem and needs to close. We are sorry for the inconvenience. Runtime Error 800A1391 happens when JavaScript fails or crashes while it’s running.
The solution to repairing the 800A1391 error code is as follows:
Solution: Update the Virus protection program or download and install the latest Windows Update.
Virus infection causes runtime errors in the computer system, and the program should be deleted immediately. Make sure that the user updates the virus program and runs the program, then scans the computer to kill the virus problem.
