JavaScript Problem in Mozilla Firefox
When I am trying to signup a gmail account. My browser seen that a Javascript problem. I am using Mozilla Firefox 10.0 version. What is the reason for this problem ?
Hi, I see that you are encountering some problems with your Java using your Mozilla Firefox browser.
There are 3 probable reasons why you encounter such problems with Java.
The version of your Java Plugin has been disabled, Â Mozilla Firefox doesn't support Java or you haven't installed Java yet.
To fix your problem we need to try some sort of solutions.
To enable or disable your JavaScript go to tools > options > content and check whether if the box where it states that Enable JavaScript is with a check mark (if none check it, Refer to the picture below).
And to double check, press Ctrl+Shift+a to open Add-ons Manager and click Plug ins and check whether the Java Plug ins are enabled. (To see how it must look like refer to the picture below)
If you don't see any Java Plug ins you must download and install Java
If problem still exist download the latest Firefox (CLICK TO DOWNLOAD) and reinstall Java.
I hope this solution will fix your problem.
