JavaScript slider slides look like abnormal how to resolve this?
Running the slider on the site looks very different. The site address is bellated dot com. You can see alternate photos that are big in size. If you leave the site and browse on other website and then come back again, the slider looks abnormally. How can I fix this issue?
Answered By 590495 points N/A #149258
I’m not sure if the link you provided is correct. I tried visiting the site but I received a 404 response on the requested page. I think the page you specified on the link was already deleted or maybe moved to a different location on the site. Anyway, if you think there is something wrong with your website’s appearance maybe you should check the CSS codes you used on the site as well as the JavaScript that runs on the site.
You may also try adding a compatibility script for older versions of Microsoft Internet Explorer.
