Javeline PVC ID Printer Mechanical Error – how to fix?
Javelin PVC ID Printer Mechanical Error – how to fix?
I am printing to Javelin S420CM PVC ID Printer.
I cannot continuously print up to 5 cards.
Before I finish the 5 sets of card the printer displays Mechanical Error on his panel.
I can’t be productive with this repeated error.
I am printing more than 1000 PVC ID.
This should be a bad luck.
Please help.
Best Answer by Montery Wilson
Answered By 0 points N/A #81553
There are several reasons why Mechanical Error encountered in your printer.
You must check the following subject matter to fix the error.
Your printer head settings might be too high. Change your printer head settings.
If you are using WinCard to print PVC ID follow the instruction below:
1. Press Ctrl + P to print then select properties on the destination printer.
2. Click the Head Settings Tab.
3. Adjust the Color Intensity set all colors to 5 as well as the Color Contrast to 5 on the Contrast set Overly Varnish to 3 and Black to 5 also Hologram for 5.
4. You may also click the defaults for the default settings.
One more factor with this error is the O-Ring driven then mechanism of the printer. This needs replacement of the O-Ring. Contact your vendor to replace the O-Ring.
Another factor is the Roller's especially the one near the head. Sometimes rollers melt and could not be able to rotate that’s why Mechanical Error appears. Replace the ruler.
The big problem is when your printer Motherboard fails to drive the mechanical parts of the printer.
Replacement of the board needed.
Answered By 0 points N/A #81555
Check your printer for any obstruction that cause stopping of the card.
Check for any tangled ribbon around the rollers.
Also check the Cleaning roller assembly.
Check if the card will slip when being passed under the head while printing, this means that the transport rollers are dirty.
You should clean the printer.
For J3J10and J4J20, set the command for the driver in the printer driver properties.
Click the manual command and enter, make sure that the printer card is ready before clicking the execute option.
Check also if it's not feeding more than one card. Never forget to clean your printer then.
