JCreator 5 Error: Cannot Find Home Directory
I am using JDK 1.6.0 21 along with JCreator 5 to make my Java-based projects. Unfortunately, I keep on uninstalling and installing both applications because of a certain error I keep on getting: "Cannot find Home Directory." I am aware that the problem may be caused by how the applications have been installed, in the first place. I am now following the instructions provided in the manual.
I tried to install the applications on two different machines, a Windows XP and a Windows 7 computer, but I still receive the error message on any of these computers.
There must be something wrong with how I installed the applications.
I have been reading a lot of solutions I can find on the Internet but nothing has worked, and now I am desperately seeking for any advice I can get from you guys.
I need to get on with my project since it has been delayed for a while now.
Error:
Javac file not found C:Program FilesXinox SoftwareJCreatorV3 LEMyProjectsProgram0202MortgageWindow . Java
Usage: javac <options> <source files>
Use -help for a list of possible options
Process completed.
