JDeveloper crashes with unexpected error
Hello, I am using JDeveloper version 11.1.2.2.0 and I have installed all the updates available.
While practicing tutorial I am getting the following error message.
And no matter what I choose from the box, my design view end up to be blank. I am having this error every time I am trying.
Please let me know what have i done wrong?
Error message: An unexpected server error has occurred in JDeveloper
The program  may be unstable, which could result in data loss. Decide how you want to proceed and click ok.
Answered By 10 points N/A #159058
Hello Bersh,
The following are the workarounds you should use to resolve the issue you are getting when running JDeveloper.
  • You will need to close all Oracle applications you are running on your computer and then restart the computer and see if that will resolve the issue. Make sure that you end the processes completely in the task manager before you restart the computer.
  • In case the error persists, you may need to uninstall the JDeveloper you have on your computer and then later on reinstall it for the one you are running right now may be unstable.
  • Otherwise, you may need to call contact Oracle support for further assistance with the issue.
Carl
