Hi there,
I have installed Jet Set Radio game on my PC with Windows 7. This game meets all my system requirements and I don’t know what is error about. I reinstalled the game as the error say and the error didn’t disappear. Someone please help me to install the game properly and tell me why I have this error ?
Thank you !
Jet Set Radio: jetsetradio.exe – Bad Image
C:Windowssystem32d3dcompiler_43.dll is either not designed to run on Windows or it contains an error. Try installing the program again
using the original installation media or contact your system administrator or the software vendor for support.
OK
Jet Set Radio shows error and says Bad Image
If we’ll look at the compatibility of the video game, there is obviously no problem. Jet Set Radio supports Windows XP Service Pack 2 and later which probably means it supports until Microsoft Windows 8.1. For the hardware, it doesn’t require a very demanding specification because it can run even on a Pentium 4 processor with at least 1 GHz speed.
The file that is in error is “d3dcompiler_43.dll”. I’m not sure if this file is included in the DirectX because after I checked my computer’s own DirectX, I didn’t find the file. I also checked the site where missing DLL files are mostly downloaded to find any information about the file but unfortunately, it is not stated in the file if it is really from DirectX.
Your best option is to download or I mean to purchase the game again from Buy Jet Set Radio on Steam. Uninstall the version installed on your computer and install the one you purchased. See if the problem is fixed. You may also try installing the latest updates for your operating system.
