Julioo
Posted on - 12/10/2011
On my computer I got JetAudio 8 free version. I wanted to upgrade it to a new version, and my friend got me a copy on USB. My computer didn’t find any viruses on USB. When I run set up, error message appear. It won’t let me to make updates.
Please help
Thank you
Julilo
jetAudio
An error [-5006: 0x80030005] has occurred while running the setup.
Please make sure you have finished any previous setup and closed other applications.
If the error still occurs, please contact your vendor; COWON
[http://www.cowonamerica.com].
Report
Detail>>
OK
JetAudio An error [-5006: 0x80030005] has occurred while running the setup
You do not need to worry about this error.
Firstly, uninstall jet audio software from your computer. After the uninstallation, please restart your system. When the computer has restarted, please follow the below procedure using a free tool ‘CCleaner’. To download free, go to http://www.piriform.com/ccleaner/download/standardand download ‘CCleaner’.
Once it gets downloaded, please install the downloaded program. When installation is completed, start the program to run the scans and tests. It will clean all messed up system files, resulting in freeing some space in your hard drive. Then, start the Registry Cleaner to fix the problems related with registry of the operating system that will be found by Registry Cleaner. You may need to start the Registry Cleaner for a couple of times to fix all the found issues, and once the Cleaner says that there is no more issue remaining. For starting Registry Cleaner, open CCleaner, then at the left of the window, click the registry link provided and that will start the Registry Cleaner. Now, start the scan and once it finishes, start the fixing of these issues. Once fixing is done, again initiate scan, and fix, until you reach no issues found.
Once cleaning and repairing of the system files and registry is done, please restart your computer, and then go to windows update, and run them. If you get any updates, first download and install those updates completely and successfully. Then again, restart your computer, and them run the setup you have I your USB, and it will install. Congrats, enjoy your new Jet Audio.
If you run the installer directly from the USB flash drive then there is no problem. As long as it is a perfectly working installer then it will install on your computer. The problem is it detected an unfinished installation on your computer. If you haven’t installed anything then your existing jetAudio 8 is probably not installed properly or maybe has an installation problem.
Try this one. Uninstall jetAudio 8, the one currently installed on your computer then restart your computer. Run the jetAudio installer that is stored on the USB flash drive and then try installing it. You can also download the latest version from jetAudio 8.1.3 Basic. It supports all versions of Microsoft Windows.
You can also download it from FileHippo, jetAudio 8.1.3 Basic.
