JetClean menu order cache removal warning
Hi experts,
JetClean came up with this error after installing was done. It worked fine on my Windows XP and now on Windows 7 is for the first time when I have this error. Can anyone help me please to fix this? Should I be worried about this error?
Thanks !
JetClean
WARNING about “Menu Order Cache”: Your Start menu will be reset. No items will be removed.
Are you sure you want to select the item?
Do not show me this message again.
